RCU Forums - View Single Post - Removing Bearings
Old 02-12-2003 | 03:51 PM
Furyflyer2's Avatar
Furyflyer2
My Feedback: (117)
Default Removing Bearings
If you can cut the arm, that will work or just gently pry the bearing out from the I.D. As long as the bearing rotates smoothly and not with a notchness the bearing is good. No you should not CA the bearing in place.
