Removing Bearings
I broke one of the seesaw arms on my Venture and the replacement arms did not come with bearings. How do I remove the bearings from the broken arms without damaging the bearings? Would it be alright to cut the broken arms to remove the bearings? When I put the bearings in the new arms should I C.A. them in place, or will they fit tight enough in the arms?
My Feedback: (117)
If you can cut the arm, that will work or just gently pry the bearing out from the I.D. As long as the bearing rotates smoothly and not with a notchness the bearing is good. No you should not CA the bearing in place.
