RCU Forums - View Single Post - Thunder Tiger Trainer 40 with MVVS engine
Old 03-06-2007 | 11:53 AM
Fastsky's Avatar
Fastsky
Default RE: Thunder Tiger Trainer 40 with MVVS engine
Most training statrs when the plane has been taken up to a safe altitude by the instructor and then throttled back top 1/2 or a bit less. He should tell you to set your throttle to about the same setting and then he will give control over to you. SO, if your are running at half or less, the extra reserve at full throttle isn't going to hurt any thing, its just there if, and when you need it![8D]
