RCU Forums - View Single Post - Need help on tuning da-50
Old 03-06-2007 | 11:55 AM
AirWizard's Avatar
AirWizard
Default RE: Need help on tuning da-50
When the high needle is to lean the rpm will drop off so richen until you have reached the max rpm. I then work on the low speed needle either leaning or richen until you get a smooth transition from idle to full throttle.
From factory setting start off leaning the high speed needle.......normally you will also lean the low end for best transition and idle.
