RCU Forums - View Single Post - Capiche 50
Thread: Capiche 50
Old 07-19-2003 | 03:25 PM
  #524
cabanestrut2002's Avatar
cabanestrut2002
Default Capiche 50
your car is getting fuller and fuller malcolm!
yep, lots of coupling with the rudder on the m j.
get yer arse in gear phil, you should have that built by now!
those panthers seem to be addicted to inverted landings, ive done fin scraping high alpha passes with mine but once the fin is touching, theres no more down elevator left!
ive bent two needle valves doing that
i do believe gwyn mentioned putting wheels on top of his mini-bipe for the display!
heres gwyn doing a low pass, the first person to guess the distance from the ground to the fin wins a dodgy vietnamese artf
