Importantly the model has been engineered for simple yet very strong construction at a minimum of weight
was gonna say, this wing TE construction is new to me, kinda makes it obvisious why i couldn't top hinge.
silly question tho... best way to fix spats? never had them before.
wheel bolt through, line up, then small hole and tiny screw to hold in place?
got them through from Carbon Copy today
At that nasty bit where you think you can start to cover, but not sure if you can.
think i'll have the lighting hole behind the wing on the underside as a hatch so i can get to the throttle servo and rudder/elevator servo leads.
then it's get the gear here and installed. wish i had the motor mount, would give me an excuse not to cover yet
