RCU Forums - View Single Post - Miss Dragon .60
Old 03-07-2007 | 11:03 AM
anonymouse
Default RE: Miss Dragon .60
If all you need is the centre of gravity or the balance point, you don't need the instructions. Normally the CG is about 1/3 the chord. Measure back from the leading edge at the side of the fuselage and use that for a starting point. It will fly, but you may want to fine tune it in to your preferences...
This is assuming the wing is a constant chord.....
