 Miss Dragon .60 >
Miss Dragon .60
Miss Dragon .60
Old 03-07-2007 | 05:38 AM
loupus's Avatar
Default Miss Dragon .60
Hi All,
Just wondering if someone can help me Please, recently I bought a generic " Dragon Lady .60", apparently still made by Modeltec but sold by the name of "Miss Dragon .60" and in red covering instead of the yellow.
It arrived in amazingly good condition compared to the box it was in, compliments of our postal service, anyway on opening the box and admiring the model I found there were no instructions and after contacting my hobby shop was told that were none included with these models so if anyone has one of these or a Dragon Lady could you help me with the measurement for the centre of Gravity please.
Cheers.
Old 03-07-2007 | 11:03 AM
Default RE: Miss Dragon .60
If all you need is the centre of gravity or the balance point, you don't need the instructions. Normally the CG is about 1/3 the chord. Measure back from the leading edge at the side of the fuselage and use that for a starting point. It will fly, but you may want to fine tune it in to your preferences...
This is assuming the wing is a constant chord.....
Old 03-07-2007 | 10:38 PM
My Feedback: (14)
ORIGINAL: anonymouse
Anonymous is dead on target.
Just measure back to the 1/3rd point of the leading edge, balance it there and you are good to go. This applies to any symmetrical or semi-symmetrical airfoil equipped, constant chord wing.
To be conservative (safe), don't include the ailerons in the calculation if they are strip ailerons. If barn door (not this model), ignore them since they are an integral part of the wing.
It needs to be said that just like "factory needle valve settings", this is a safe starting point. Not the final/finest position. However, if you are happy with how the model flies with this CG position - just leave it like it is.
Ed Cregger
Old 03-08-2007 | 05:31 PM
I just checked the instructions that accompanied my 60 sized Dragon Lady from Model Tech. 4" to 4 1/4" behind the leading edge is the recommendation in the manual. I have been flying mine at the 4 1/4" mark since the spring of '99 and am very happy with it.
Old 03-15-2007 | 08:34 PM
Just use this it will be spot on every time.. No guess work needed
http://www.coloradogliders.com/cente...calculator.htm
