RCU Forums - View Single Post - Drifting Suspension TT-01
Old 03-07-2007 | 02:11 PM
dorkymk3
Default RE: Drifting Suspension TT-01
it all depends on what tires you run. For the start with abs tires run soft springs all around with 20w or 30w shock oil. With yokomo's i run medium springs front with 30w and stiff on rear with 30w. but its basically all on how you want your car to be. I find it hard to control the car with softer suspension due to the sensitivity it gets to the surface, but it has the best control over all when chaning transitions from one way to the other.
