RC Drifting Discuss all aspects of rc drifting here!
Drifting Suspension TT-01
Old 03-07-2007 | 12:10 PM
Default Drifting Suspension TT-01
Howdy,
I have a TT-01 and ive put some new tyres on it and its amazing to see how easy it is to drift. I have the standard TT-01 it came with no mods but I put an aluminium prop shaft in it. I want to upgrade to the oil filled shocks but which are the best size to get for drifting?
Many Thanks
Old 03-07-2007 | 02:11 PM
Default RE: Drifting Suspension TT-01
it all depends on what tires you run. For the start with abs tires run soft springs all around with 20w or 30w shock oil. With yokomo's i run medium springs front with 30w and stiff on rear with 30w. but its basically all on how you want your car to be. I find it hard to control the car with softer suspension due to the sensitivity it gets to the surface, but it has the best control over all when chaning transitions from one way to the other.
Old 03-07-2007 | 04:36 PM
Lets get a Ball bearing kit for it first, ditch the stock plastic ones and then look at Oil filled shocks..
I use Eagle racing Shocks on my TT-01 with 40 Weight oil and medium springs all round..
