RCU Forums - View Single Post - 9303 program problems(me)
Old 03-07-2007 | 03:01 PM
Checklst
Default 9303 program problems(me)
Hey guys....Danny I just went through the H9 Ultra Stick and I am having problems. I am using the downloaded programming guide fo the 9303 for the H9 Ultra Stick.
First why can I not turn off the Elev to flap mix..... it mixes the up flap to up elev All THE time...it would be fun for tight loops but I can't get it to shut off for normal flying.
Second I'm having trouble with the Aileron to Flap mix I have set it up as per direction and the top right flip switch turns it on and off but no matter what I do the Flaps go in the opposite direction as the ailerons. I have walk through the directions 3 times now. I really would like full ailerons for some quick spins and for slow landings need the prop wash on the Ailerons surfaces.
Since I was having trouble with the Elev to flap mix I went back and took all the values out shut it off because I could not find out how or what switch controlled it...........does this have an effect on the Aileron to flap problem I'm having.
Thanks in advance........... sheeeese this thing is kicking my A__ I had my 8103 set up this way and even had crow but the 9303 is beating me up.
Dave.
BTW the H9....9303 and the G26 look great.
