Capiche 50
indeed its all about throws...
use the aerobatic set up on one switche and the 3D on the other...
It is a small pattern style model, with classic looks, and large control surfaces.
We have carefully designed the kit and construction and I believe that if a builder sticks to the plan and instructions there should be no problem.... weve driven them hard on 2 and 4 stoke and no signs of flutter... Ive seen them being flown faster then I fancy but still fine....
When you fly it though you will discover that you dont want to drive fast.... it does pattern stuff nice and slow because it has a modified pattern style wing as opposed ot a fun fly section, and it is very light.
The rudder is very big but very well behaved.....
Jees Im hot... its about 35 here today !
