RCU Forums - View Single Post - Direct Drive CPP Setup
Old 03-07-2007 | 05:03 PM
almaidah
Default RE: Direct Drive CPP Setup
ok i will tell you. iT is ok, its normal as long as it spins.. you may have to ajust the pot settings because after installing the bl and dd you will see a difference.. hope it helps
