RCU Forums - View Single Post - Capiche 50
Thread: Capiche 50
Old 08-09-2003 | 07:40 AM
  #919
grahamd1
Default Capiche 50
Played with trying to sort out the throttling problem this morning. Cleaned everything, checked all the pipes for leaks, changed the filter, checked the system for presure, and back outside to try again.
Still wont throttle
Took it back in the garage, thats it I'm taking that carb apart
Hello whats this , only one screw holding the carb on, and thats loose. No wonder it wont throttle, been sucking in air all over the place.
Take the carb off anyway, to check it over, bugger me where the second screw should go, there wasnt even a screw hole
Take one drill and sloooooowly drill out the carb, then tap it, and now find a screw to fit. Voila the carb feels solid.
Take it back outside, wahay, two tanks of fuel and she has full responce right down to the slowest tickover I've seen, push the stick and growl, where back in business. (I bet the neighbours are just as happy as me )
I'm gonna wring this "friskey filley" this Sunday up the field.
So check those new SC, ASP and Magnums, anc make sure those two screws are doing the job. Unlike mine
