Capiche 50
I think ive got the same set as Surret3styla.
I think they are 3mm thick rods horns and ball links. Unfortunately the HS 945 coreless i got from als hobbies is too big to put in the rudder servo hole at the back. It sticks out too far and clashes with the elevator. Looks like i will be using a closed loop for the rudder again like The Boy.
I have got a question about the knife edge coupling. I understand that cplr said it needed more dihedral. Surely you could get around this by chamfering the wings tips at an angle like on the Chris Foss range of kits?
