RCU Forums - View Single Post - Capiche 50
Thread: Capiche 50
Old 08-19-2003 | 11:25 AM
  #999
Ultimate
Default Capiche 50
the rudder / aileron coupling is there but its slight enough to manually correct it. If anything the rudder / elevator coupling is slightly worse and worth mixing out for KE
C of G - I started in the middle and gradually moved it back until I just need a hint of down when inverted. This gives it good waterfall and KE loop ability, but its still smooth enough for pattern style aeros on low rates.
Chris
