in that case, remove all your keyboard buttons, push random ones and replace the key with that symbol there. or just swap your keyboard settings to UK not USA
my rudder is -80% on HIGH 3D rates.
good news is, the Capiche is an all weather plane, tho the smoothness is lost to the bumps being lightly loaded. landings alot easier too
i found my stall turns tended to weathercock around a bit.
Jamie had a go, called it class and flew the tank dry
then deadsticked it in long grass.. wheels came off again. guess i'm going to metal bolts, just that small plate worries me.. would be happier if it was wider and had a better glue footprint.
looking at our rules for the upcoming fly for fun, it'll be great for the aero moves seeing as the winner last year used a Rapier.. 4 point roll
just spot landing is a worry at the mo. dropping a Cougar deadstick on the spot is much easier than gliding in a Capiche
Maybe i'll get 6" soft foam wheels for that event
