Capiche 50
were you using foam wheels?They absorb shock a bit better.
The 6mm plastic bolts i use take a hell of a lot of punishment before they break. The plate on ours is really strong, so hopefully it wont happen with it.
The wheels dont have much clearance from the capiche spats, so that could be the problem. maybe the wheels need mounting further out from the spat.
Guess i will find out when my Saito 72 deadsticks. On saturday i had a dead stick with my cub during knife edge at 8 feet! luckily still made the runway. Hopefully i will have the same luck as the Capiche.
