were you using foam wheels
yep, 2.5" ones, tho the foams a little hard ( ripmax ones )
The 6mm plastic bolts i use take a hell of a lot of punishment before they break
i've got 5 i think.. the black ones took more than the clearish
The wheels dont have much clearance from the capiche spats, so that could be the problem. maybe the wheels need mounting further out from the spat.
no spats on today, they haven't caused a problem when they were on, other than tearing through the wing. however this was the reason i was surprised both sides are cut. i would have thought this was left to the user so you can raise them up. seeing as i've redone them i'll add some material so i can do that
