RCU Forums - View Single Post - 9303 program problems(me)
Old 03-08-2007 | 12:31 PM
Checklst
Default RE: 9303 program problems(me)
Thanks Danny..... hear is an up date...........I have just completed all direction up to Aileron to flap mix and Flap mix to Aileron the last 2 section. At this point every things work perfect, I have Ailerons on the outboard(both sides)proper direction,elevator(normal)rudder (Normal) I have down flaps in position 1 and full down flaps in position 2 and it gives me 1/4 inch down elev. With all switches in o position and moving the far back/right switch forward I have flaps coupled to the elev I get up flaps if I pull up elev for tight loops.
I'm confused of how all the rest of the direction are tied to this switch also.......
AT this point if I program the last 2 sections Aile to flap and flap to Ailer it goes nuts..............after programing IF I PULL THE FAR/RIGHT/BACK SWITCH FORWARD the flaps go opposite of each other and reverse of the ailerons IF I use the aileron control stick the Ailerons go up the 3/4 inch.........and if I pull UP on the elevator the flaps go down the same amount the elevator goes up..........other than the flaps opposite of each other and opposite of Ailer I understand this is normal......
Right now I'm thinking of flying just like it is and just not have FULL strip AILERON or the Crow type feature. IS their any way just to add FULL STRIP AILERON to a switch and not have ANY OF the crow feature...........
I really only want FULL STRIP AILERON over what I (first paragraph)have now I would trade off all this crow(up elev,...down flap ....up elev) and even up flap to the elev if I could get it)
I've owned JR for 6 years now 8103 to the 9303 and had my 8103 programmed just like this on a SR telmaster so I've been hear before and your direction only took me 15min or so on the 8103..........I've been at this 9 hours over 2 days ..........RANT over..........
I understand you last line of a+ a- so all give that a try.....
Thanks Again
