RCU Forums - View Single Post - Capiche 50
Thread: Capiche 50
Old 08-30-2003 | 04:07 PM
  #1228
Luke 3D returns's Avatar
Luke 3D returns
Default Capiche 50
Thanks for the Tip Sprink. I dont think i will need it because when the engines upsidedown the silencer will be directed more downwards and away from the needle valve.Let me know how the Special silencer and pump go.I should compare Tachometer readings with you sometime to see if they make a big difference.
Wildnloose,
If you look at what Ali Machinsky has said about it on the Capiche website you will find a very detailed description on how the 50 size version flies.
I havent flown mine yet,so i dont know how accurate Ali's description is, but this is one of the best freestyle pilots in the UK talking!
Its been said by others that they wont prophang as well as a hype3D or similar.
Also,according to www.flycapiche.co.uk CPLR said it could do with a bit more dihedral for knife edge manuvers.
Another thing is that the instructions did not come with our kit. I dont know if this is typical of all the kits, but if so this might be a problem for a customer without internet access being unable to print a copy off the web.
Thats my "2 cents"!
