RE: Not Moving?
hey Magikman, Welcome to the forum and welcome to CEN Genesis Series ownership. This is a common question, first I 'll ask if you checked ALL of your screws to be sure they were ALL tight?? Then check your set screws on the drive inputs into the front and rear differentials, They are most likely loose or not tightened up on the flat portion of the pinion shaft. Just take out the set screw, put just a dab of blue or red locktite on the screws threads, line up the hole on the flat and reinsert the set screw and tighten as tight as you can get it. Do this on both inputs and you should be good to go...
And as far as the brakes go. You need to adjust them and the radio to push better and harder on the brake cam lever. You could even do endos when the brakes are set properly so be careful not to adjust too much stopping into it.
BTW I would respectfully suggest you use the search feature to see if you question has been asked before. And if you ask and dont get a response, that usually means it has been asked before. Just a friendly suggestion.
Good luck and have fun!!!
