RCU Forums - View Single Post - Not Moving?
Thread: Not Moving?
Old 03-08-2007 | 10:32 PM
The Real Dogman's Avatar
The Real Dogman
Default RE: Not Moving?
Also, you did not mention anything about a break-in. What break-in procedure did you use?
So if I understand you. You can start the truck, idle it up to temprature(BTW what temp does it get up to and what temp did you break it in at?) drive it slowly around but when you quickly pull the throttle trigger it bogs down? right?
If thats true then you still need to lean out the HSN, until it no longer bogs when you hammer it, if that does not help then go the other way(richen it up)..You could Definitely benefit from a tuning dial to help.
You can find the best available @ [link=http://www.rchardware.com]http://www.rchardware.com[/link]. And they are on sale this month!!!! There are now 2 versions, Race and Sport. Very high quality and the price is very right. I have three 2 sports and and a race, it made my tuning SOOO much easier!! Try it out you'll like it!! I promise..
And dont forget to have fun!!
ID:	638212   Click image for larger version
