RCU Forums - View Single Post - New Engine now available
Old 03-09-2007 | 11:20 AM
rmh's Avatar
rmh
Default RE: New Engine now available
engine is 4 pounds -- not 3 lbs so it is heavier than the lighter 50s but same as 3W essentially
very smooth runner - easy start - no leaks easy restarts -low vibes -all in all very nice engine. good quality!
the muffler sounds quite nice -for in cowl muffler- and does not harm power on the 24x8 - quite a surprise.
I would use it on this engine if I was to use in cowl muffler .
I would take it over any of the piston ported designs in that weight range 50-60 cc - -Having run Zenoah and Fuji in this size /weight --They both had notable vibration at 3000 --this one has none there - just a little bit right at 2200.
