ORIGINAL: ccameselle
atmycabin thank you for your answer. Do you have the one with the pull pull for the ruder or do you have the servo at the tail? Also how is the CG? Do you have it at the default location? did you have to add weigth anywhere?
Thank you in advanced.
CC[8D]
I left everything according to manual (servo set-up, CG, throws, rates). Just be creative with the battery location when balancing. This bird will maiden just fine if you follow the instructions.
