Seduction?
I have the FS and ONO special. The ONO is alot more that just bigger ailerons. All the geomoterty has been changed. The ailerons are deeper and in set into the wing, so not increasing the wing area. they are built into the wing and cut out in the same way as the elevator. The tail plane is moved up a little, I guess mkeing knife edge totally neutral.
So I think that this is the truest flying aircraft in its class.
Kris.
