BVM aggressor II vs. Aggressor III
Shawn,
There are PLENTY of differences between the two. I've owned both. The Agg. III is MUCH easier to build (More prefabrication) as it has pre-sheeted flying surfaces, pre-primed glass parts, holds more fuel, and is larger than the AGG. II. The airfoil is better on the AGG. III and the hatches fit much nicer. If you have a choice go with the AGG. III!!! It builds much the same as a Balsa Bandit except the wings on the AGG.III are presheeted. . (Not the new Super Bandit)
Kevin
