BVM aggressor II vs. Aggressor III
My Feedback: (85)
Shawn,
There are PLENTY of differences between the two. I've owned both. The Agg. III is MUCH easier to build (More prefabrication) as it has pre-sheeted flying surfaces, pre-primed glass parts, holds more fuel, and is larger than the AGG. II. The airfoil is better on the AGG. III and the hatches fit much nicer. If you have a choice go with the AGG. III!!! It builds much the same as a Balsa Bandit except the wings on the AGG.III are presheeted. . (Not the new Super Bandit)
Kevin
Kevin
Kevin,
Thanks for the info. I just saw a II for sale for what look like a good price and thought I might consider it. I would rather have a f-16 anyway.
Thanks again for the reply
Shawn
Shawn
My Feedback: (10)
FL
hello
I have had both and they are totally different ships. The 3 is larger and has a much better engineered wing. Both high and low speed flying are enhanced. The 3 can also be very easily converted to turbine operation. The 2 is small. Not good access to the gear in the nose and is simply inferior to the 3.
Spend the money on the 3 and you will be glad you did..
JB
JB
They both fly great... and the II can be made quite a bit lighter for great vertical. In general, the III is more modern, easier to build, and enhanced.
I still have and fly and original Viper
D
D
