RE: Nitro models pusher Bobcat?
After checking your connections and your battery (under load) you may want to replace the Deans. Deans sometimes have problems within the electronics at the base you will not see until you hit a certain vibration frequency. This is also true for receivers. I use the Revolution as the base is hard molded or a full length whip.
