RE: Top Flite Cessna 182 build
Dont' worry about showing your age. On the internet, it's all about just showing that your not a punk teenager w/ to much time on your hands!! :-)
By the way, I did an inventory on my kit and found out that I'm missing a wing bolt. I recommend you do an inventory as well if you have not already. I emailed top flite and got a response back the same day. They are shipping me the missing bolt, as well as a replacement windshield because mine arrived w/ dents in it.
The perry pump works on crankcase pressure, right? That is probably why they don't recommend them for twins. But if the 100 fires both cylinders at the same time it should have similar crank pressure fluctuations to a single... Something else to look into. Even with a pump though, you still have to find a way to put fuel in the wing.
