Hi guys !?? I have just found out that my sailcalc on my broadsheet had a incorrect formulae in it
with the result my top rig had 200 sq.ins to much!!!!The only good thing to come out of this is that the speeds my multihull has been getting has been true to the actual sail but not its calculated area.
I am in the process of checking both my sailcalcs,to make sure they are correct.You see it pays to have a cold as it forces you to do other things in your misery.Like checking sail areas by hand[ie.not using calculator]
It's time I asked the spiders to vacate my multihull,or learn to swim!If you read this Idealist ,how is your new multi coming along?Come on guys it's sailing time again !Regards to all
Scotty
