Use Fuel Tubing
John,
The groove in the nose ring is designed to use Fuel line as the isolation material. You can use large silicone tubing and it should work fine....If its too tight try the Med...I know the guys are using med tubing on the OS 140's and the YS has a Smaller diameter housing than the OS.
Troy Newman
