Angel's Shadow nose ring size
My Feedback: (7)
Does anybody have the size O-ring that fits in a standard YS nose ring. I have an Angel's Shadow and it just takes the rubber inset and not the entire unit. Also, any source would be helpful. Someone said it is a #25, but not positive. Thanks in advance. John S. Johnson
John,
The groove in the nose ring is designed to use Fuel line as the isolation material. You can use large silicone tubing and it should work fine....If its too tight try the Med...I know the guys are using med tubing on the OS 140's and the YS has a Smaller diameter housing than the OS.
Troy Newman
Troy Newman
My Feedback: (7)
Troy,
Thanks a bunch!! I couldn't figure it out and I was pulling my hair out going to all the gasket stores... I've got one more question. Do you silicone it in or friction fit it? BTW, I'm putting a DZ in it as you recommended at TOC. See you at the local meets. John Lubbock, TX
Try the friction fit...that is what the guys have done...but you may need silicone...I don't think it does....but.....
Local contests for me are now in Northern California....We are just leaving the house for the Phoenix contest....It will be a little out of the way 700miles...but last year we did the 950 miles from Denver down to it.
Talk to you soon
Troy Newman
Talk to you soon
Troy Newman
