RCU Forums - View Single Post - Matrix TR Arena Shock Spring's
Old 03-16-2007 | 07:34 AM
The Real Dogman's Avatar
The Real Dogman
Default RE: Matrix TR Arena Shock Spring's
Sometimes when the caps on plastic shocks get tightened too much it will deform the top of the tubes enough it will cause the tubes to "grab" the shock pistons and result in full compression binding. check the shock caps see if loosening the caps "release" the shocks. If you have aluminum shocks, then ignore what I just said.
Have fun
