Matrix TR Arena Shock Spring's
Hi Guys,
Did anyone find any problem's with the rear spring's of the Matrix TR Arena as when
you press down the truggy it won't recoil back up.
Any info pls post.
Any info pls post.
Sometimes when the caps on plastic shocks get tightened too much it will deform the top of the tubes enough it will cause the tubes to "grab" the shock pistons and result in full compression binding. check the shock caps see if loosening the caps "release" the shocks. If you have aluminum shocks, then ignore what I just said.
Have fun
Have fun
CA
Adjsut the shock spacer and the shock mounting on the shock tower and sus. arm. http://www.cenracing.com/race/pic/trsetuphighbite.jpg
