RE: Eflite Blade CX
Check the mixer box in the front canopy. There's a little dial that adjusts the motor speeds. The included flat screwdriver fits the adjustment dial, just be careful, it's delicate. Also, if you break it they're $40-$50 to replace. If that doesn't work, check the upper blade motor. They are pretty cheap and wear out. On the bright side, they're cheap to replace. Good luck.
