RE: Trainer Choice (again)
No APC props on trainers or tail draggers with inexperienced pilots, one prop strike and you can toss them in the trash, same with wood props. You get a better idle with a composite prop anyway, it's heavier and acts like a flywheel, engine doesn't loose as many RPM between combustion strokes thus a smoother idle.
The most durable training prop is the black Master Airscrew, and don't bother using the pretty spinner that comes with the plane, use a "spinner-nut" (looks like a round nose aluminum bullet with a hex on the back) because it makes maintenance at the field much faster and easier.
Remember, a trainer is a tool to teach you to fly so keep it simple and the more complicated you make your training the more aggravated you make your instructor....[:@]
Carlos (X instructor) Murphy
