RE: Problem With Engine Tuning
The main two reasons I would guess to be your problem.
1 Not enough pitch set. At about half throttle on the TX you should have about 6 degrees, full throttle about 9-11 degrees pitch. It sounds like you may only have (say 2) degrees at half throttle.
2 Too much throw on your throttle servo therefore you may have full throttle on your carb although your TX is only set at half.
