ORIGINAL: Carlos Murphy
No APC props on trainers or tail draggers with inexperienced pilots, one prop strike and you can toss them in the trash, same with wood props. You get a better idle with a composite prop anyway, it's heavier and acts like a flywheel, engine doesn't loose as many RPM between combustion strokes thus a smoother idle.
The most durable training prop is the black Master Airscrew, and don't bother using the pretty spinner that comes with the plane, use a "spinner-nut" (looks like a round nose aluminum bullet with a hex on the back) because it makes maintenance at the field much faster and easier.
Remember, a trainer is a tool to teach you to fly so keep it simple and the more complicated you make your training the more aggravated you make your instructor....[:@]
Carlos (X instructor) Murphy
I though I read APC was good for beginners. O well, Ill check out Master Airscrew.
Whats the difference between these two...
http://www2.towerhobbies.com/cgi-bin...?&I=LXZ965&P=7 and
http://www2.towerhobbies.com/cgi-bin...?&I=LXAA21&P=7 . Which should I get? And do these need to be balanced? And do I need one of those reamers under the required section? Would a normal drill be fine?
