RCU Forums - View Single Post - Source for Airodynamic Aluminum
Old 03-19-2007 | 10:52 AM
jeff1127
Default RE: Source for Airodynamic Aluminum
Check ebay for 6061 T6 aluminum if it is a structural repair. You didn't specify thickness though.
The above can be shaped if need be but you must heat the material first. If you google it you will be find all you need to know to work with it.
