 Source for Airodynamic Aluminum >
Old 03-19-2007 | 09:48 AM
Default Source for Airodynamic Aluminum
I need a piece of "airodynamic aluminum" 3/8" wide, about 8" long to complete a repair of a plane. I have not be able to locate a supplier for this product. Any suggestions?
Old 03-19-2007 | 10:52 AM
Default RE: Source for Airodynamic Aluminum
Check ebay for 6061 T6 aluminum if it is a structural repair. You didn't specify thickness though.
The above can be shaped if need be but you must heat the material first. If you google it you will be find all you need to know to work with it.
