Originally posted by Soar Head
Trimming the edges
I suggest completely trimming the extra cloth. Before joining the wing halves, completely trim all surfaces so that they are perfectly flush with the surface of the flange of the mold. This is easiest done while the epoxy is partially cured. Easy to cut with a single edged razor blade, but stiff enough to hold it's shape. Then you require a relatively small amount of spooge (epoxy & cabosil) to join the wing halves.
I'm learning a lot of stuff from this thread.
One question about the quote above. How can you trim the extra cloth while the epoxy is partially cured if you are bagging the wing? Do you have to stop the vacuum and pull everything out at just the right time, or what?
