RCU Forums - View Single Post - Problem with pushrods binding on yak54 41"
Old 03-19-2007 | 03:09 PM
Mattacks
Default RE: Problem with pushrods binding on yak54 41"
Yes this is an electric arf. I've tried putting the pushrods on opposing sides of the servo, but that doesnt really work (pushrods rubbing together) They are side by side. I can see that some of the fuselage formers are warped through the clear covering on the plane and this is throwing the pushrods off a little also where they exit the plane. I think the during build I should have installed the pushrods and tested out where they travel before choosing the final location of the control horns as you need cut out a hole and glue them in place. Oh well learn as you go! I'll be doing my next build a little different.
As a last ditch effort Im going to cut out the other two push rod supports on the fuse formers and enlarge the holes where the push rods exit the fuse. This will ensure a straight path to control horns. hope it dosent make the rods to wobbly though
Thanks for your suggestions everyone.
