RE: Phoenix Extra 330S 60-90 Size
If you run dual elevators on a 7c, then you can only trim one servo with the trim button. The 7C doesn't support dual elevator servos. You can mix them together, but like I said, only the master channel will trim, and the slave will always be centered. Just an fyi.
