RCU Forums - View Single Post - Official XTM X-Cellerator thread!!
Old 03-20-2007 | 04:33 PM
  #1005
ecfarr
Default RE: Official XTM X-Cellerator thread!!
what do you mean when you say the clutch bell wall might be glazed?
also, I opened the clutch bell and on the inside found a lot of metal shavings. Is this normal? could one of the bearings in the clutch bell be bad?
also, when I now tighten the clutch nut, the clutch bell will not spin without the engine turning over also. If I move the car on the ground it is hard to move it and I can hear the engine make a rotation (that soft puff sound). Should the clutch bell be able to move independently from the engine piston?
