RCU Forums - View Single Post - poulan 46
Thread: poulan 46
Old 03-20-2007 | 06:50 PM
Antique's Avatar
Antique
Default RE: poulan 46
The gap between the mag rotor and coil should be as close as possible without rubbing...No way to boost a weak magneto spark.....It gets stronger as the rpm increases....They don't need to be strong at low rpm because the chainsaws use a pull starter, as opposed to airplane engines that are hand propped...The old Quadra with points and the G38 are about the easiest starting magneto gassers...
Moderator added the suffix "out" onto the word "with" which is, IMHO, Ralph's intention?
