RCU Forums - View Single Post - Wing Tip Clearence
Old 03-21-2007 | 11:10 AM
extra260bum
Default RE: Wing Tip Clearence
as long as your rear stabilizer is parrallel to the wing you should be fine. I'm sure it won't be anything that a little trim can't fix. You might end uip worse off if you try to take that much off the other wing.
