RCU Forums - View Single Post - Eagle 50 questions
Old 03-22-2007 | 05:43 PM
yadac123
Default RE: Eagle 50 questions
Yes the DC plug to the TX is actually for testing at the assembly. So the ac that come with it is 12V so it can be used on the TX but then it's not portable.
for the simulator i only got it to work once with the real flight simulator and that's a very old version and it was free. It's windows 2000
ok make sure you serial port is turn on.
ORIGINAL: scarpa
Hi and thanks for the forum.
I just got an Eagle 50 and have a few questions.
Can the AC adapter for the battery charger be used to power the Tx too?
Also, I've been trying to connect to a sim program with the supplied cable, but haven't had any luck. I'm using WinXP and have tried it with ClearView and the Reflex XTR Demo. I also tried connecting through the sound card with SmartPropoPlus and PPJoy. I get some kind of signal, but nothing stable enough to set up or calibrate.
Any help would be appreciated.
Joe
