Here is "Lundy's" address:
[email protected]
I'm sure he won't mind answering your questions. One option is ordering a Safety and Sound Module from Paramax. Their address is:
[email protected] Web Site is
http://www.paramax.de/
This device has two purposes, one to switch on the receiver when a static line is pulled from the module and the other is a trace signal in the event the jumper lands in a "bad place" Turn off the TX (Sender) and the signal starts to beep.
The other option is a pin on the back pack which prevents opening the pack until a static line removes the pin. In this case, the RX can be lurned on when on the ground.
Hope this helps
Paul
