RCU Forums - View Single Post - where to put tape for the panel lines
Old 03-23-2007 | 04:53 AM
RubenJ
Default where to put tape for the panel lines
Hi,
I have built a tf-p47 and I have already glassed it and put the primer on it. Now I want to make the panel lines. I am going to use a soft pencil to write the panel lines on it and then i want to put the tape on it. Do you have to put the tape on the panel lines (so the panel lines are under the tape) or next to the panel lines? It's a bit confusing cause i've seen some pictures where peaple put the tape next to the panel lines. But I've also read that you have to put the tape over the panel lines. Can someone tell me where to put the tape?
